Changing Duty Status
For the most accurate records, you must change your duty status in the Garmin eLog™ app every time you change your driving status, such as when you start driving, take a break, switch drivers, or change the type of driving you are doing. The Garmin eLog adapter automatically switches to driving status when the vehicle's diagnostic port reports a speed greater than or equal to five miles per hour. The vehicle is stopped when the diagnostic port reports a speed of zero miles per hour.
NOTE: The vehicle must be stopped to change duty status. You cannot manually change duty status while you are driving.
  1. Select an option:
    • From the Garmin eLog app, select Cambia stato servizio.
    • From the Garmin eLog map tool, select the driver name.
  2. Select an option:
    NOTE: The Personal Conveyance and Yard Moves options are available only if the administrator has enabled them for your driver profile (Editing a Driver Profile).
    • If you are on duty, select On Duty.
    • If you are off duty, select Off Duty.
    • If you are on duty and driving, select Driving.
    • If you are moving to the sleeper berth, select Sleeper Berth.
    • If you are using the vehicle for personal conveyance, select Personal Conveyance.
    • If you are moving the vehicle within the yard, select Yard Moves.
GUID-104136B1-8D89-47E2-8799-55395E18A7C3 v8
Ottobre 2023
