Formatting the Memory Card
The device requires a memory card formatted using the FAT32 file system. You can use the device to format your card using this file system.
You must format a brand new memory card if it is not formatted using the FAT32 file system.
NOTE: Formatting the memory card deletes all data on the card.
  1. Select Settings > Device > Storage & USB.
  2. Select your memory card.
  3. Select Menu > Settings > Format > ERASE & FORMAT.
  4. Select Done.
GUID-104136B1-8D89-47E2-8799-55395E18A7C3 v8
October 2023
