Adjusting the screen brightness
The device can use an ambient light sensor to adjust the screen brightness to your vehicle conditions automatically (Display settings). You can also adjust the brightness manually using either the notification panel or the settings menu.
  1. Select an option:
    • Swipe down twice from the top of the screen to expand the quick settings in the notification panel.
    • Select Settings > Device > Display > Brightness Level.
  2. Use the slider bar to adjust the brightness.
GUID-104136B1-8D89-47E2-8799-55395E18A7C3 v8
October 2023
