Setting a Recurring Alert
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
  1. Hold Menu symbol.
  2. Select Ride Settings > Alerts.
  3. Select an alert type.
  4. Turn on the alert.
  5. Enter a value.
  6. Select Start symbol.
Each time you reach the alert value, a message appears. The device also beeps if audible tones are turned on (Turning the Device Tones On and Off).
Copyright © Garmin. All rights reserved.GUID-0E629F64-4ADF-459F-8A85-1E28685E4ED4 v1
