System Settings
Hold
, and select
System.
- Language
Sets the language displayed on the device (Changing the Device Language).
- Backlight
Sets the backlight timeout, brightness, and behavior (Using the Backlight).
- Sounds
Turns audible tones on or off for keys and alert messages (Turning the Device Tones On and Off).
- Units
Sets the units of measure used on the device.
- Time
Sets the device to display time in a 12-hour or 24-hour format.
- Position Format
Allows you to set the format for viewing geographical coordinate position details.
- Auto Power Off
Allows you to set the device to automatically power down after 10 minutes of inactivity.
- Reset
Allows you to reset the system settings or delete all user data (Restoring All Default Settings).
- About
Displays the software version and unit ID, and allows you to check for software updates (Viewing E-label Regulatory and Compliance Information).
- Changing the Device Language
- Using the Backlight
- Turning the Device Tones On and Off
- Changing the Units of Measure
- Using the Auto Power Off Feature
