Installing the Risers
For the most accurate weight measurement, you should use the device on a hard, flat floor. If you plan to use your device on a carpeted floor, you should install the included risers. The risers are not necessary when you use the device on a hard floor.
Press a riser onto each foot on the device.
Riser placement with an arrow
GUID-0BADEBCF-960D-4961-856C-86B9204BC169 v4
March 2026
