Rudder Gain Settings
If you set these values too high or too low, the autopilot may become overactive, attempting to constantly adjust the heading at the slightest deviation. An overactive autopilot can cause excess wear on the actuator and drain the battery at a faster-than-normal rate.
On a helm control or the autopilot screen on a chartplotter, select .
- Gain
Allows you to adjust how tightly the rudder holds a heading and makes turns.
- Counter Gain
Allows you to adjust how tightly the rudder corrects turn overshoot. If you set this value too low, the autopilot can overshoot a turn when attempting to counter the original turn.
Parent Topic: Detailed Configuration Settings
