Select an option:
If you are performing this procedure as part of the
Sea Trial Wizard, select
Begin.
If you are performing this procedure outside of the
Sea Trial Wizard, on a helm control or the autopilot screen on a chartplotter, select
Follow the directions until calibration is complete, taking care to keep the boat as steady and flat as possible.
The boat should not list during calibration. Make sure one side of the vessel is not loaded more heavily than the other.
Select an option:
If the calibration is not successful, repeat the previous step.
If the calibration completes successfully, select
Next.
When the calibration is complete, a magnetic environment quality value is shown. A value of 100 indicates the CCU was installed in a perfect magnetic environment and calibrated correctly. If this value is low, you might need to relocate the CCU and calibrate the compass again.
