Pairing Your Phone
To use the connected features of the Edge® bike computer, it must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your phone.
  1. Hold Power button symbol to turn on the device.
    The first time you turn on the device, you will select the device language. The next screen prompts you to pair with your phone.
    TIP: You can swipe down on the home screen to view the status widget, and select Phone > Pair Smartphone to manually enter pairing mode (Viewing Widgets).
  2. Scan the QR code with your phone, and follow the on-screen instructions to complete the pairing and setup process.
    NOTE: Setting up Wi‑Fi® and sleep mode usage on your device enables the device to sync with all your data such as training stats, course downloads, and software updates.
After you pair successfully, a message appears, and your bike computer syncs automatically with your phone.
GUID-08ACA9FC-DEE6-4C8D-8A95-F62181C512E9 v2
September 2024
