Tips After Pairing the Devices
  • After the initial pairing, the two devices can connect automatically each time you turn them on.
  • When you turn on the device, it tries to connect to the last phone to which it was connected.
  • You might need to set your phone to connect to the device automatically when the device is turned on.
  • You should verify the Bluetooth® features you want to use are enabled (Enabling or Disabling Bluetooth Features).
Copyright © Garmin. All rights reserved.GUID-03E29042-23C8-4418-8521-2AAEA94C7400 v5
