Tips after pairing the devices
After the initial pairing, the two devices can connect automatically each time you turn them on.
When you turn on the device, it tries to connect to the last phone to which it was connected.
You might need to set your phone to connect to the device automatically when the device is turned on.
You should verify that the Bluetooth® features you want to use are enabled (Enabling or Disabling Bluetooth Features).
Parent Topic: Pairing with Your Smartphone
