Turning the device on or off
  • To turn the device on, press the power key Call-out number one or connect the device to power.
    Power button on the side of the device with a callout
  • To put the device in power saving mode, press the power key while the device is on.
    While in power saving mode, the screen is off and the device uses very little power, but it can wake instantly for use.
    TIP: You can charge your device faster by putting it in power saving mode while charging the battery.
  • To turn off the device completely, hold the power key until a prompt appears on the screen, then select Power off.
Copyright © Garmin. All rights reserved.GUID-03E29042-23C8-4418-8521-2AAEA94C7400 v5
