Adjusting the screen brightness
You can adjust the brightness manually, using either the notification panel or the settings menu.
  1. Select an option:
    • Swipe down twice from the top of the screen to expand the quick settings in the notification panel.
    • Select Settings > Device > Display > Brightness level.
  2. Use the slider bar to adjust the brightness.
Copyright © Garmin. All rights reserved.GUID-03E29042-23C8-4418-8521-2AAEA94C7400 v5
