Editing an Alarm
  1. Select an option:
    • From the watch face, hold Middle-left button.
    • From the watch face, press Upper-right button.
    • Hold Upper-left button.
  2. Select Clocks > Alarms.
  3. Select an alarm.
  4. Select an option:
    • To turn the alarm on or off, select Status.
    • To change the alarm time, select Time.
    • To set an alarm to gently wake you in the 30-minute window before your scheduled alarm based on optimal sleep timing, select Smart Wake.
      NOTE: Your alarm will always go off at your selected time in addition to any earlier alarms. For example, if you set your alarm for 8:00 am, the alarm may gently alert you to wake up some time between 7:30 and 8:00 am.
    • To set the alarm to repeat regularly, select Repeat, and select when the alarm should repeat.
    • To select the type of alarm notification, select Sound & Vibe.
      NOTE: You can also preview the alarm sound, adjust the volume, and select vibration options. Select Quiet Start if you want your alarm to start quietly and then get louder.
    • To select a description for the alarm, select Label.
  5. Select an option:
    • To save your edits, select Done.
    • To delete the alarm, select Delete.
GUID-025D75CF-3445-49E1-8D81-1AA74AB4E00F v5
June 2026
