Using ClimbPro
The ClimbPro feature helps you manage your effort for the upcoming climbs on a course. You can view climb details, including gradient, distance, and elevation gain, before or in real time while following a course. Cycling climb categories, based on length and gradient, are indicated by color.
  1. Hold Menu symbol.
  2. Select Activities & Apps.
  3. Select an activity.
  4. Select the activity settings.
  5. Select ClimbPro > Status > When Navigating.
  6. Select an option:
    • Select Data Field to customize the data field that appears on the ClimbPro screen.
    • Select Alert to set alerts at the start of a climb or at a certain distance from the climb.
    • Select Descents to turn descents on or off for running activities.
    • Select Climb Detection to choose the types of climbs detected during cycling activities.
  7. Review the climbs and course details for the course (Viewing Course Details).
  8. Start following a saved course (Navigating to a Destination).
GUID-0221611A-992D-495E-8DED-1DD448F7A066 v11
April 2026
