Installing the Device
To ensure maximum tail light visibility and radar detection range, you should install the mount according to these considerations.
  • Make sure the device does not interfere with the safe operation of your bike.
  • Install the mount as high as possible on the bike.
  • Mount the device 250 to 1200 mm above the road.
  • Mount the Varia™ RearVue 820 device parallel to the longitudinal axis of the vehicle.
  • Make sure there are no obstructions in front of the light.
  • Make sure the mount surface is perpendicular to the road.
    Device mounted on a bike
  • Make sure the device faces straight back, so that the radar beam covers the maximum range behind your bike.
    Overhead view of radar beam
You should go for a test ride during the day, in a safe environment, and adjust the mount, if necessary, before using the tail light at night.
GUID-00DDE23B-43B0-4A55-8168-14192C225EEB v3
August 2026
