Cycling Dynamics
Cycling dynamics metrics measure how you apply power throughout the pedal stroke, and where you apply power on the pedal, allowing you to understand your particular way of riding. Understanding how and where you produce power allows you to train more efficiently and evaluate your bike fit.
NOTE: You must have a compatible, dual sensing power meter to use cycling dynamics metrics.
For more information, go to Garmin.com.sg/minisite/cyclingdynamics.
Using Cycling Dynamics
Before you can use cycling dynamics, you must pair the Vector power meter with your device (Pairing Your Wireless Sensors).
NOTE: Recording cycling dynamics uses additional device memory.
- Go for a ride.
- Scroll to the cycling dynamics screen to view your power phase data
, total power
, and platform center offset
- If necessary, hold a data field
to change it (Adding a Data Screen).NOTE: The two data fields at the bottom of the screen can be customized.
You can send the ride to the Garmin Connect app to view additional cycling dynamics data (Sending Your Ride to Garmin Connect).
