Customizing Vector Features
Before you can customize Vector features, you must pair a Vector power meter with your device.
- Select
> Sensors. - Select the Vector power meter.
- Select Sensor Details > Vector Features.
- Select an option.
- If necessary, select the toggle switches to turn on or off torque efficiency, pedal smoothness, and cycling dynamics.
Updating the Vector Software Using the Edge Device Before you can update the software, you must pair your Edge device with your Vector system.
- Send your ride data to your Garmin Connect account (Sending Your Ride to Garmin Connect).
Garmin Connect automatically looks for software updates and sends them to your Edge device.
- Bring your Edge device within range (3 m) of the sensor.
- Rotate the crank arm a few times. The Edge device prompts you to install all pending software updates.
- Follow the on-screen instructions.
