Light Network Settings
From your Edge® device, select Menu symbol > Settings > Sensors > Lights, and select a paired light.
Enable
Turns on the light and allows you to control the light remotely with your Edge device. You can disable a light to disconnect it from the light network.
Light Mode
Sets the light intensity and pattern mode, or turns off the light.
NOTE: This setting is available when you select the Individual light mode setting (Light Mode Settings).
Software Update
Checks for software updates.
About
Displays device, software, and battery information.
Remove
Allows you to delete a paired light from the network.
Copyright © Garmin. All rights reserved.GUID-F8DAD96C-F2E0-4339-806E-61CE31348354 v3
