Engine Alert Icons
Red icons indicate engine abnormalities.
Consult your Yamaha® dealer if the problem cannot be located and corrected.
Low cooling water pressure. |
Low oil pressure. Stop the engine. Check the engine oil level, and add more oil if necessary.
Do not continue to run the engine if this indicator is on. Serious engine damage will occur. |
Engine overheating. Stop the engine immediately. Check the cooling water inlet, and clear it if it is blocked. Do not continue to run the engine if this indicator is on. Serious engine damage will occur. |
Low battery voltage. Check the battery and battery connections, and tighten all loose battery connections. Return to port soon if tightening the battery connections does not increase the battery voltage. Consult your Yamaha dealer immediately. NOTE:
Do NOT stop the engine when this alert is on. If you do, you may not be able to restart the engine.
Water in the fuel. Water has collected in the fuel filter (fuel separator). Stop the engine immediately and consult the engine manual to drain the water from the fuel filter. NOTE:
Gasoline mixed with water might cause damage to the engine.
Check engine/maintenance alert. Consult your Yamaha dealer immediately. The check engine alert also appears when more than 100 hours have elapsed since the previous maintenance. |
Engine alert notification. (Helm Master®) |
Engine emission issue. |
