Radar Installation Settings
- Front of Boat
Compensates for the physical location of the radar when it is not on the boat axis (Front-of-Boat Offset).
- Antenna Configuration
Sets the radar antenna size and sets the position in which the radar stops (Setting a Custom Park Position (open array antenna)).
- No Transmit Zone
Sets the area in which the radar does not transmit signals (Enabling and Adjusting a Radar No Transmit Zone).
Measuring and Setting the Front-of-Boat Offset
The front-of-boat offset compensates for the physical orientation of the radar scanner on a boat, if the radar scanner does not align with the bow-stern axis. The front-of-boat offset setting configured for use in one radar mode is applied to every other radar mode and to the radar overlay.
- Using a magnetic compass, take an optical bearing of a stationary target located within viewable range.
- Measure the target bearing on the radar.
- If the bearing deviation is more than +/- 1 degree, set the front-of-boat offset.
- From a radar screen, select .
- Select Up or Down to adjust the offset.
By default, the antenna is stopped perpendicular to the pedestal when it is not spinning. You can adjust this position.
- From the radar screen, select .
- Use the slider bar to adjust the position of the antenna when stopped, and select Back.
