Tips for Missing Running Dynamics Data
If running dynamics data does not appear, you can try these tips.
  • Make sure you have a running dynamics accessory, such as the HRM‍-‍Tri™ accessory.
    Accessories with running dynamics have Runner symbol on the front of the module.
  • Pair the running dynamics accessory with your Forerunner® device again, according to the instructions.
  • If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up.
    NOTE: Ground contact time and balance appears only while running. It is not calculated while walking.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
