Viewing Measured Shots
Before the device can automatically detect and measure shots, you must enable scoring.
Your device features automatic shot detection and recording. Each time you take a shot along the fairway, the device records your shot distance so you can view it later.
TIP: Automatic shot detection works best when you wear the device on your leading wrist and make good contact with the ball. Putts are not detected.
  1. While playing golf, select START > Measure Shot.
    Your last shot distance appears.
    NOTE: The distance automatically resets when you hit the ball again, putt on the green, or move to the next hole.
  2. Select DOWN to view all recorded shot distances.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
