Tips for Missing Running Dynamics Data
If running dynamics data does not appear, you can try these tips.
  • Make sure you are using the HRM‍-‍Run™ accessory or HRM‍-‍Tri™ accessory.
    The heart rate monitor has Runner symbol on the front of the module.
  • Pair the heart rate monitor with your Forerunner® again, according to the instructions.
  • If the running dynamics data display zeros, make sure the module is worn right-side up.
    NOTE: Ground contact time appears only while running. It cannot be calculated while walking.
Copyright © Garmin. All rights reserved.GUID-3F6E0495-3A1D-49FA-888B-B002BB2B6114 v5
