Going for a Run Using a Foot Pod
Before you go for a run, you must pair the foot pod with your Forerunner® device (Pairing Your ANT‍+ Sensors).
You can run indoors using a foot pod to record pace, distance, and cadence. You can also run outdoors using a foot pod to record cadence data with your GPS pace and distance.
  1. Install your foot pod according to the accessory instructions.
  2. If necessary, select > Activity Settings > GPS to turn on or turn off GPS.
  3. Select Start symbol to start the timer.
  4. After you complete your run, select Start symbol > Save.
Copyright © Garmin. All rights reserved.GUID-3F6E0495-3A1D-49FA-888B-B002BB2B6114 v5
