Putting On the Heart Rate Monitor
You should wear the heart rate monitor directly on your skin, just below your sternum.
  1. Select a strap extender for the best fit.
  2. Wear the heart rate monitor with the Garmin® logo facing right-side up.
    The hook Callout number one and loop Callout number two connection should be on your right side.
    Heart rate device with callouts
  3. Wrap the heart rate monitor around your chest, and connect the strap hook to the loop.
    Heart rate device placement on the chest
    NOTE: Make sure the care tag does not fold over.
  4. Tighten the heart rate monitor so it is snug around your chest, but not restrictive.
After you put on the heart rate monitor, it is active, storing, and sending data.
Copyright © Garmin. All rights reserved.GUID-3F6E0495-3A1D-49FA-888B-B002BB2B6114 v5
