Using Virtual Partner
Your Virtual Partner® is a training tool designed to help you meet your goals. You can customize the Virtual Partner to run at a target speed or pace.
  1. Select > Settings > Activity Settings > Data Screens > Virtual Partner > Status > On.
  2. Select Set Pace or Set Speed.
    You can use pace or speed as your running format (Format Settings).
  3. Go for a run.
  4. Scroll to the Virtual Partner screen to see who is leading.
    Virtual Partner data with a callout
  5. If necessary, hold the Virtual Partner banner Callout number one to adjust the pace or speed of the Virtual Partner during your run.
Copyright © Garmin. All rights reserved.GUID-281F05D9-D51E-4CD6-9D43-C10041A6C65B v5
