Setting Range Alerts
A range alert notifies you when the device is above or below a specified range of values. For example, if you have an optional heart rate monitor, you can set the device to alert you when your heart rate is below zone 2 and over zone 5 (Setting Your Heart Rate Zones).
  1. Select Menu > Activity Settings > Alerts > Add New.
  2. Select the type of alert.
    Depending on your accessories and the activity profile, the alerts may include heart rate, pace, speed, and cadence.
  3. If necessary, turn on the alert.
  4. Select a zone or enter a value for each alert.
Each time you exceed or drop below the specified range, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-B15C42C1-C24E-41B8-A0DC-3944D1DBDB2A v5
