Broadcasting Heart Rate Data to Garmin Devices
You can broadcast your heart rate data from your Forerunner® device and view it on paired Garmin® devices. For example, you can broadcast your heart rate data to an Edge® device while cycling, or to a VIRB® action camera.
NOTE: Broadcasting heart rate data decreases battery life.
  1. Select to view the heart rate widget.
  2. Hold .
  3. Select Broadcast Heart Rate.
    The Forerunner device starts broadcasting your heart rate data, and Heart rate broadcast symbol appears.
    NOTE: You can view only the heart rate page while broadcasting heart rate data.
  4. Pair your Forerunner device with your Garmin ANT‍+® compatible device.
    NOTE: The pairing instructions differ for each Garmin compatible device. See your owner's manual.
    TIP: To stop broadcasting your heart rate data, select any key, and select Yes.
Copyright © Garmin. All rights reserved.GUID-B15C42C1-C24E-41B8-A0DC-3944D1DBDB2A v5
