Going for a Run
The device comes partially charged. You may need to charge the device (Charging the Device) before going for a run.
  1. Hold Power symbol to turn on the device.
  2. From the time of day screen, select any key (except Backlight symbol), and select Runner symbol to unlock the device.
  3. Go outside, and wait while the device locates satellites.
    It may take a few minutes to locate satellite signals. The satellite bars turn green, and the timer screen appears.
    Activity timer with run data
  4. Select Runner symbol to start the timer.
  5. Go for a run.
  6. After you complete your run, select Runner symbol to stop the timer.
  7. Select an option:
    • Select Resume to restart the timer.
    • Select Save to save the run and reset the timer. A summary appears.
      Activity timer with run summary
      NOTE: You can now upload your run to Garmin Connect™.
    • Select Discard to delete the run.
Copyright © Garmin. All rights reserved.GUID-0B08B4AE-BDDB-4FCE-91C9-3D320A32397F v7
