Creating a Workout
  1. Select Training > Workouts > Create New.
  2. Enter a workout name, and select Checkmark.
  3. Select Step Type to specify the type of workout step.
    For example, select Rest to use the step as a rest lap.
    During a rest lap, the timer continues to run and data is recorded.
  4. Select Duration to specify how the step is measured.
    For example, select Distance to end the step after a specific distance.
  5. If necessary, enter a custom value for the duration.
  6. Select Target to choose your goal during the step.
    For example, select Heart Rate Zone to maintain a consistent heart rate during the step.
  7. If necessary, select a target zone or enter a custom range.
    For example, you can select a heart rate zone. Each time you exceed or drop below the specified heart rate, the device beeps and displays a message.
  8. Select Checkmark to save the step.
  9. Select Add New Step to add additional steps to the workout.
  10. Select Checkmark to save the workout.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
