Planning and Riding a Course
You can create and ride a custom course. A course is a sequence of waypoints or locations that leads you to your final destination.
- Select Navigation > Courses > Course Creator > Add First Location.
Select an option:
To select your current location on the map, select Current Location.
To select a saved location, select Saved, and select a location.
To select a location for which you recently searched, select Recent Finds, and select a location.
To select a location on the map, select Use Map, and select a location.
To browse for and select a point of interest, select POI Categories, and select a nearby point of interest.
To select a city, select Cities, and select a nearby city.
To select an address, select Addresses, and enter the address.
To select an intersection, select Intersections, and enter the street names.
To use coordinates, select Coordinates, and enter the coordinates.
Select
Use.
TIP: From the map, you can select another location, and select Use to continue adding locations.
- Select Add Next Location.
- Repeat steps 2 through 4 until you have selected all locations for the route.
Select
View Map.
The device calculates your route, and a map of the route appears.
TIP: You can selectto view an elevation plot of the route.
- Select Ride.
