Power and Data Cable
  • The wiring harness connects the device to power and NMEA® 0183 devices. 6-inch devices can also use these wires to share user data, such as waypoints and routes.
  • If you are not connecting NMEA 0183 devices or another chartplotter to share data, disregard the blue and brown wires.
  • The device has one internal NMEA 0183 port that is used to connect to NMEA 0183 compliant devices.
  • If it is necessary to extend the power and ground wires, you must use 0.82 mm2 (18 AWG) or larger wire.
  • If it is necessary to extend the NMEA 0183 or alarm wires, you must use .33 mm2 (22 AWG) wire.
Wiring diagram with callouts
Item
Wire Function
Wire Color
Callout number one
NMEA 0183 internal port Rx (in)
Brown
Callout number two
NMEA 0183 internal port Tx (out)
Blue
Callout number three
Ground (power and NMEA 0183)
Black
Callout number four
Power
Red
Copyright © Garmin. All rights reserved.GUID-D68475AC-7C3A-4AEB-9E3D-345C8DC1B376 v3
