NMEA 2000 Considerations
NOTICE
If you are connecting this device to an existing NMEA 2000® network, the NMEA 2000 network should already be connected to power. Do not connect the NMEA 2000 power cable to an existing NMEA 2000 network, because only one power source should be connected to a NMEA 2000 network.
If you are connecting this device to an existing NMEA 2000 network or engine network by another manufacturer, you should install a NMEA 2000 Power Isolator (010-11580-00) between the existing network and the Garmin® devices.
NOTICE
If you are installing a NMEA 2000 power cable, you must connect it to the boat ignition switch or through another in-line switch. NMEA 2000 devices will drain your battery if the NMEA 2000 power cable is connected to the battery directly.
NOTE: NMEA 2000 is not available on all models.
NMEA 2000 compatible models can connect to a NMEA 2000 network on your boat to share data from NMEA 2000 compatible devices such as sensors or a VHF radio. The necessary NMEA 2000 cables and connectors are sold separately.
If you are unfamiliar with NMEA 2000, you should read the “NMEA 2000 Network Fundamentals” chapter of the Technical Reference for NMEA 2000 Products. To download this document, go to www.garmin.com and select Manuals on the product page for your device.
The port labeled NMEA 2000 on the cradle is used to connect it to a standard NMEA 2000 network.
Wiring diagram with callouts
Item
Description
Callout number one
NMEA 2000 compatible Garmin device
Callout number two
NMEA 2000 drop cable
Callout number three
Callout number four
Ignition or in-line switch
Callout number five
12 Vdc power source
Callout number six
NMEA 2000 terminator or backbone cable
Callout number seven
NMEA 2000 T-connector
Callout number eight
Copyright © Garmin. All rights reserved.GUID-D68475AC-7C3A-4AEB-9E3D-345C8DC1B376 v3
