Data Fields
Some data fields require ANT+® accessories to display data.
The current left/right power balance.
The 10-second moving average of the left/right power balance.
The 30-second moving average of the left/right power balance.
The three-second moving average of the left/right power balance.
The average left/right power balance for the current activity.
The average left/right power balance for the current lap.
The remaining battery power.
The remaining battery power of a bike light accessory.
The headlight beam mode.
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cycling. The average cadence for the current activity.
Cycling. The average cadence for the current lap.
The amount of total calories burned.
During a workout, the remaining calories when you are using a calorie target.
The remaining distance to the next point on the course.
The remaining battery power of a Di2 sensor.
The current shift mode of a Di2 sensor.
The distance traveled for the current lap.
The distance traveled for the last completed lap.
The remaining distance to the final destination. You must be navigating for this data to appear.
During a workout or course, the remaining distance when you are using a distance target.
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
The distance traveled for the current track or activity.
The distance ahead or behind the Virtual Partner®.
The altitude of your current location above or below sea level.
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
The front bike gear from a gear position sensor.
The battery status of a gear position sensor.
The current gear combination from a gear position sensor.
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
The front and rear bike gears from a gear position sensor.
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 3.65 m (12 ft.).
The strength of the GPS satellite signal.
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
The direction you are moving.
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
The percentage of maximum heart rate.
The average heart rate for the current activity.
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
The average percentage of maximum heart rate for the current activity.
A line graph showing your current heart rate zone (1 to 5).
The average heart rate for the current lap.
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
The average percentage of maximum heart rate for the current lap.
The average heart rate for the last completed lap.
During a workout, the amount you are above or below the heart rate target.
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
The number of laps completed for the current activity.
The light network configuration mode.
The number of connected lights.
The last point on the route or course.
The next point on the route or course.
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
The average platform center offset for the current activity.
The average platform center offset for the current lap.
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
The performance condition score is a real-time assessment of your ability to perform.
The current power output in watts. Your device must be connected to a compatible power meter.
The current power output as a percentage of functional threshold power.
The 10-second moving average of power output.
The 30-second moving average of power output.
The 3-second moving average of power output.
The average power output for the current activity.
The Intensity Factor™ for the current activity.
The accumulated work performed (power output) in kilojoules.
The average power output for the current lap.
The top power output for the current lap.
The average power output for the last completed lap.
The top power output for the current activity.
The Normalized Power™ for the current activity.
The average Normalized Power for the current lap.
The average Normalized Power for the last completed lap.
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
The average power phase angle for the left leg for the current activity.
The average power phase angle for the left leg for the current lap.
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
The average power phase peak angle for the left leg for the current activity.
The average power phase peak angle for the left leg for the current lap.
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
The average power phase angle for the right leg for the current activity.
The average power phase angle for the right leg for the current lap.
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
The average power phase peak angle for the right leg for the current activity.
The average power phase peak angle for the right leg for the current lap.
The Training Stress Score™ for the current activity.
The amount of power output in watts per kilogram.
The current range of power output (1 to 7) based on your FTP or custom settings.
The rear bike gear from a gear position sensor.
During a workout, the remaining repetitions.
The current rate of travel.
The average speed for the current activity.
The average speed for the current lap.
The average speed for the last completed lap.
The top speed for the current activity.
The time of sunrise based on your GPS position.
The time of sunset based on your GPS position.
The target power output during an activity.
The temperature of the air. Your body temperature affects the temperature sensor.
The stopwatch time for the current activity.
The time ahead or behind the Virtual Partner.
The average lap time for the current activity.
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
The time elapsed in each heart rate or power zone.
The stopwatch time for the current lap.
The stopwatch time for the last completed lap.
The time of day based on your current location and time settings (format, time zone, daylight saving time).
The time spent seated while pedaling for the current activity.
The time spent seated while pedaling for the current lap.
The time spent standing while pedaling for the current activity.
The time spent standing while pedaling for the current lap.
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
During a workout, the remaining time when you are using a time target.
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
The measurement of how efficiently a rider is pedaling.
The total elevation distance ascended since the last reset.
The total elevation distance descended since the last reset.
The resistance force applied by an indoor trainer.
The rate of ascent or descent over time.
The 30-second moving average of vertical speed.
During a workout, the current step out of the total number of steps.
