Pairing Your ANT+® Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of ANT+ wireless sensors, for example, connecting a heart rate monitor with your Garmin® device.
- Bring the device within 3 m (10 ft.) of the sensor.
- Select .
Select an option:
A list of available sensors appears.
- Select one or more sensors to pair with your device.
Select
Add Sensor.
When the sensor is paired with your device, the sensor status is Connected. You can customize a data field to display sensor data.
