Charging the Device
The device is powered by a built-in lithium-ion battery that you can charge using a standard wall outlet or a USB port on your computer.
NOTE:
The device will not charge when outside the approved temperature range (Edge® Specifications).
Pull up the weather cap
from the USB port
- Plug the small end of the USB cable into the USB port on the device.
- Plug the large end of the USB cable into an AC adapter or a computer USB port.
Plug the AC adapter into a standard wall outlet.
When you connect the device to a power source, the device turns on.
- Charge the device completely.
