JavaScript must be enabled in order to use this site.Please enable JavaScript in your browser and refresh the page. Using the Weight Scale If you have an ANT+® compatible weight scale, the device can read the data from the weight scale. Select Menu > Settings > Sensors > Add Sensor > Weight Scale. A message appears when the weight scale is found. Stand on the scale when indicated. NOTE: If using a body composition scale, remove shoes and socks to ensure that all body composition parameters are read and recorded. Step off the scale when indicated. TIP: If an error occurs, step off the scale. Step on when indicated. Garmin Index Smart Scale Data
