Putting On the Heart Rate Monitor
You should wear the heart rate monitor directly on your skin, just below your sternum. It should be snug enough to stay in place during your activity.
Snap the heart rate monitor module
onto the strap.
The Garmin® logos on the module and the strap should be right-side up.
Wet the electrodes
and the contact patches
on the back of the strap to create a strong connection between your chest and the transmitter.
Wrap the strap around your chest, and connect the strap hook
to the loop
The Garmin logos should be right-side up.
- Bring the device within 3 m (10 ft.) of the heart rate monitor.
After you put on the heart rate monitor, it is active and sending data.
TIP:
If the heart rate data is erratic or does not appear, see the troubleshooting tips (Tips for Erratic Heart Rate Data).
