Installing the Cadence Sensor
Select the band size that fits your crank arm
securely.
The band you select should be the smallest one that stretches across the crank arm.
- On the non-drive side, place and hold the flat side of the cadence sensor on the inside of the crank arm.
Pull the bands
around the crank arm, and attach them to the hooks
on the sensor.
Rotate the crank arm to check for clearance.
The sensor and bands should not contact any part of your bike or shoe.
- Take a 15 minute test ride and inspect the sensor and bands to ensure there is no evidence of damage.
