JavaScript must be enabled in order to use this site.Please enable JavaScript in your browser and refresh the page. Changing the Units of Measure You can customize units of measure for distance and speed, elevation, temperature, weight, position format, and time format. Select Menu > Settings > System > Units. Select a measurement type. Select a unit of measure for the setting.
