Following a Segment From Garmin Connect™
Before you can download and follow a segment from Garmin Connect, you must have a Garmin Connect account (Garmin Connect).
- Connect the device to your computer using the USB cable.
- Go to connect.garmin.com.
- Create a new segment, or select an existing segment.
- Select Send to Device.
- Disconnect the device, and turn it on.
- Select .
- Select the segment.
- Select .
