Pairing Your Smartphone
To use the connected features of the Edge® device, it must be paired directly through the Garmin Connect™ Mobile app, instead of from the Bluetooth® settings on your smartphone.
- From the app store on your smartphone, install and open the Garmin Connect Mobile app.
Hold
to turn on the device.
The first time you turn on the device, you will select the device language. The next screen prompts you to pair with your smartphone.
- Select an option to add your device to your Garmin Connect account:
After you pair successfully, a message appears, and your device syncs automatically with your smartphone.
