Replacing the Heart Rate Monitor Battery
- Use a small Phillips screwdriver to remove the four screws on the back of the module.
Remove the cover and battery.
- Wait 30 seconds.
- Insert the new battery with the positive side facing up.
- Replace the back cover and the four screws.
After you replace the heart rate monitor battery, you may need to pair it with the device again.
