JavaScript must be enabled in order to use this site.Please enable JavaScript in your browser and refresh the page. Setting Your Elevation If you have accurate elevation data for your present location, you can manually calibrate the altimeter on your device. Go for a ride. Select > Set Elevation. Enter the elevation, and select .
