Including Transmitters in Gas Consumption Calculations
Gas consumption and air time remaining estimates are calculated using the tank pressure from the included transmitters. By default, the first transmitter that you pair with your compatible dive computer is included. You can include additional paired transmitters in gas consumption calculations.
  1. Hold MENU.
  2. Select Dive Setup > Air Integration > Transmitters.
  3. Select a paired transmitter.
  4. Select the SAC/RMV/ATR toggle switch to include the transmitter in gas consumption calculations.
  5. If necessary, repeat steps 2 through 4 to include additional paired transmitters in gas consumption calculations.
Copyright © Garmin. All rights reserved.GUID-4A2D3019-BA14-49BD-B371-4214D187D493 v2
