Pairing with Your Smartphone
Your vívofit® 3 device must be paired directly through the Garmin Connect™ Mobile app, instead of from the Bluetooth® settings on your smartphone.
  1. From the app store on your smartphone, install and open the Garmin Connect Mobile app Garmin Connect symbol.
  2. Press the device key Callout number one to turn on the device.
    Front view of the device with a callout
    The first time you turn on the device, it is in pairing mode.
    TIP: You can press the device key until Pair symbol appears to manually enter pairing mode.
  3. Follow the instructions in the app to create an account and set up your device.
    NOTE: The setup may include a software update which can take several minutes. Keep your device near your smartphone until setup is complete.
After setup is complete, the device continuously tracks your daily activity. You should sync your device often to review your progress in the app.
Copyright © Garmin. All rights reserved.GUID-12D38168-B49D-42C5-9995-333ED6398570 v5
