Pairing ANT‍+ Sensors
The first time you connect an ANT‍+® sensor to your device, you must pair the device and sensor. After the initial pairing, the device automatically connects to the sensor when you start your activity and the sensor is active and within range.
NOTE: If your Edge® 25 device was packaged with an ANT‍+ sensor, they are already paired.
  1. Install the sensor or put on the heart rate monitor.
  2. Select Down arrow > Settings > Connect Sensors.
  3. Bring the device within 1 cm of the sensor, and wait while the device connects to the sensor.
    When the device detects the sensor, a message appears.
Copyright © Garmin. All rights reserved.GUID-6882FA4B-64B0-40CE-A594-989B4BFF2D8E v3
